OBD plug wiring 94 850
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
So I have come to the conclusion after trying many obd dongles and scanners that there is something wrong with my wiring as I can't scan- Is there a simple wiring diagram that I can follow to figure out what wires in the plug go where on the ecu ?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'94 models have obdI system.
They produce flash codes and their obdI system is under the hood.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I need more data....you can't just "switch" to different engine management without serious modifications.
'94 20v n/a cars use Jetronic engine management.Sensors are different,emissions,wiring...etc.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- skloon
I swapped in an ME 4.4 ECU still using all the 850s other bits- is a turbo car- when I first swapped I used my automatic ecu then switched to a manual one- now I am using a slightly reprogrammed 4.4 one-
- Year and Model: Many Volvos
- Been thanked: 76 times
You can pull the schematics from:
http://www.volvowiringdiagrams.com/
As far as I know the OBD-II is the same between the 4.3 and the 4.4 but you may need to disconnect the OBD-I stuff to get to work.
Pull the schematics for a '98 70 series as well since that will be for a 4.4 for sure. I think the '97 has both the 4.3 and the 4.4 listed as well and it would be interesting to compare them for differences.
- misha
Lee was faster!
Yes....motronic 4.3 & 4.4 have the same communication "k-line" path via obdII.
Do you have communication to any module in the car?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Do you still have a M4.3 ECU? Put it in and see if you can get OBDII working.
When I used the m4.4 ECU on my 94 850 turbo, OBDII work just fine. No modification to the car's wiring whatsoever.
Read.
http://m44.wikia.com/wiki/M44_Wiki
Yes, you can, with M4.3 850, using a M4.4 ECU.misha wrote:I need more data....you can't just "switch" to different engine management without serious modifications.
Read.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- misha
If you read the thread more carefully from the begining,you would see that i thought he have n/a car...and UP TO '96 ,20V cars have Jetronic engine management.tryingbe wrote: Yes, you can, with M4.3 850, using a M4.4 ECU.
Read.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 3276 Views
Last post by Sommerfeldt
- 821 Views
Last post by Pistol Pete H
- 171 Views
Last post by InfiniteJESP
- 3048 Views
Last post by Roger_850T
- 1787 Views
