2013 s60 did frt brakes now grinding? Topic is solved
Anthony303
- Year and Model: 2013 s60
I have 2013 S60 T5 AWD 29K cars been sitting rotors got really rusty, replaced front rotors and put ceramic pads on now they grind I have no clue? Also have a secondary issue abs traction code frt driver speed sensor failure well I replaced it and still code is on
Did you strip the calipers when you replaced the rotors, if the rotors were rusted there is every possibility the calipers will be corroded. I always strip my calipers when I fit new pads, check the dust boots, inspect the pistons for rust, remove the seals and replace if required and hone the cylinders. Past issues with pads not releasing from the discs awakened me to the need to do this.
Anthony303
Rechecked and used advise cleaned caliper and removed pins cleaned and worked sliders real good most of problem gone except drivers side when I turn it hear some grinding possibly shield?
- 1172 Views
Last post by RussB
- 5788 Views
Last post by vtl
- 1486 Views
Last post by panda30
- 1629 Views
Last post by cn90
- 2232 Views
Last post by Sixthandredline
