car starts cold but once warm dies on me
flahaye
Year and Model: 2000 V70
Post by flahaye »
OK,
Here how it goes.
Volvo V70 SE 2000 350K km on it.
1) when the car is cold, it starts no problem
2) When the car is warmed up, the car won`t start.
- All lights are on
- I can only here some kind of hissing noise.
- After a few minutes of trying, it does start.
Any clues gentlemen ???
Thanks
Francois
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Is the lamda light on? Have you had the codes checked? Does the temperature gauge read normally?
It could be many things but without a scan it will be difficult to tell.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
How hot is it in Montreal this time of year?
M1 10W-30 HM
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Symptoms are very suggestive of bad ECT sensor.
I used to live in Montreal, same weather as Burlington VT or Albany NY etc.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Bad ECT sensor is a good idea.
You can check the ECT's resistance to find out, e.g. https://www.matthewsvolvosite.com/forums/vie ... 6&start=28
flahaye
Post by flahaye »
Thanks for the answer. I will check. But in fact. No codes from lambda.... Weather is not that hot. Just that when engine is warm i cant get the car to start. When i try to start the engine I get the hissing noise with sometimes engine reving up. After 10-20 times it starts. But sometimes it starts systematically. No problems...
Has thanked: 2197 times
Been thanked: 1850 times
Check for vacuum leaks. Car runs richer when cold, and maybe running lean when hot. Also check fuel pressure at the rail when cold and hot.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
flahaye wrote:Thanks for the answer. I will check. But in fact. No codes from lambda.... Weather is not that hot. Just that when engine is warm i cant get the car to start. When i try to start the engine I get the hissing noise with sometimes engine reving up. After 10-20 times it starts. But sometimes it starts systematically. No problems...
So its cranking over but won't start?
Or does or just hiss when I try to crank it over?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
flahaye
Post by flahaye »
Sorry guys got sidetracked by persoanl issues.
For the last post. I just hear the hissing noise. No cranking.
I got suggestion to replece the ignition switch but same issue.
Let me know if any other ideas.
It is getting annoying be ause car starts in the morning but when istop anywhere, it can take up to 5 minutes before it starts.
Always hearing that hissing noise but at one point it cranks up.
Thanks
Francois
Check the fuel pressure. Needs to be >43 psi. Once warm I find the pump pressure drops off. Have you replaced the fuel relay?
Have the car read for failure codes. Could also be an issue with the ETM.
