I just ordered a new camshaft solenoid for my 2000 XC since I'm getting the codes for it.
When I got it, that's all I got, and it's got a different connector than the one that's currently in my car. The one that is there has the big plug that goes directly into the back of it, while the one I got has the small connector that faces forward.
How do I wire this thing up?
Replacing camshaft solenoid in 2000 V70 XC?
- Year and Model: Many Volvos
- Been thanked: 76 times
There was a design change and you have to splice the solenoid into the harness. You can use butt splices but I prefer to use solder and heat shrink.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
I got mine from Volvo that came with new connector and wires.
Cut the old wires and replaced with ones from Volvo.
BUT that didn`t help with the problem. Seems it could be the camshaft position sensor.
That I only can get from Volvo, but it`s expensive
I had seen the second post (viewtopic.php?21162) before I posted.
The issue is I got NO wiring with my new one. The first topic sounds like it would work fine IF I had an old coolant temperature sensor connector.
This is my issue: I don't have a new style connector- where can I get one?
- 4653 Views
Last post by oragex
- 13280 Views
- 13 Replies
- 1295 Views
Last post by Vova585
- 1190 Views
Last post by Sommerfeldt
- 724 Views
