On my first drive of any real distance, the 2000 V70XC I just purchased threw a check engine light after about 30 minutes down the road. Checking the fuel cap is always my first “go to”. It wasn’t loose, but it was an after-market fuel cap. A quick trip to AutoZone to get the error code showed a slow leak in the vapor containment system. This furthered my thinking that it was possibly this replacement fuel cap.
Today I was at the end of the quarter tank of fuel the car had in it when I bought it, so I stopped for a fill up. Car was near empty, indicator on red, fuel light on, 20 miles remaining on the trip computer.
While fueling, the gas station pump would shut off after a second or two of running and the car will splash fuel from the fill port like it was full. After a couple times of trying with the same result, I started the car again, shut it off. After this action, the car fueled up as expected.
My issue sounds similar to this one, but other suggestions are appreciated:
https://www.matthewsvolvosite.com/forums ... +fuel+tank
Thanks,
Can't fill fuel tank
configsys
- Year and Model: V70R
- Has thanked: 2 times
- Been thanked: 5 times
I believe the culprit is a bad charcoal cannister.
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Mine does the same thing maybe once every few months. I generally try to never let the tank go less than half empty, and like you mentioned, the problem typically resolves itself after a few minutes or a little driving.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
This happens to me periodically, and there are a few specific pumps that seem most likely to do it. I just hold the pump at a very low flow rate by hand, and that prevents it from shutting off.
- 29 Replies
- 7554 Views
- 1682 Views
- 2062 Views
Last post by polskamafia mjl
- 2863 Views
Last post by Archer
- 3870 Views
Last post by Blacklab467
