Hi All,
I ran through the obd1 1 st 3 testing modes in the auto transmission diagnosis PDFs. Went fine. I don't understand test mode 4. Activating individual components. I pressed 4 times, but don't u stand how to enter in the component test? For example press 4 times, then press 3,4,2 should be number 1 shift solenoid. Nothing happens. Also where do I read my multimeter values for the 3 tranny solenoids?
Thanks in advance.
Jack
How do I check tranny solenoids value, with ohm meter?
adventurer2112
- Year and Model: 95 850 na
- Been thanked: 7 times
adventurer2112
HI All,
I got the obd1 A test mode 4 to work. Went through each component. Yay, no DTC reported yet. Will try it again, in the morning. Got in the car afterwards and the ABS TRAC warning light was on. Turned car off and back on, no ABS TRAC. Weird to me that those lights came on with the Tranny test mode 4 components test check.
Thanks
Jack
Thanks
Jack
adventurer2112
The answer is in self diagnosis downloadable service manual PDFs .
- 3653 Views
Last post by don98s90
- 1338 Views
Last post by MarcM
- 1854 Views
- 1810 Views
Last post by MrAl
- 13 Replies
- 5442 Views
Last post by SuperHerman
