1994 850 shakes
ChadLee
- Year and Model: 1998 V70
- Has thanked: 6 times
There is a local posting for a 850 with clean title that suddenly started shaking. She said it leaked a little oil, nothing major. Had regular oil changes. Suddenly the car started shaking and she parked it and did not look back. Selling it for parts. Is there anything that I can look for when I go see the car? Maybe something that went really wrong or something that can be tweaked easily and roll it on out of there. Or, should I just never approach the project? Thank you for any words of advice.
1986 245 DL, 1989 244, 745 Turbo and 1981 245 DL - gone to new homes
1989 245 GL - Wife's daily driver
1989 245 DL - In the works for a daily
1998 V70 - Daily driver
2001 V70 - Next project
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Shaking is usually a misfire.
ashitaka695
- Year and Model: 1994 850
Is the "shake" something that happens while it's being driven or just while it is running? I have a 94 850 and while it sits and idles it will give a little vibration or shake. Mine is from the motor mounts needing to be replaced. Also while driving it starts to shake going over 70 I'm pretty sure its the bushings and tie rods. These are a few things on mine that causes the little quirks.
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
My money is on misfire.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
+1. Or someone switched the ignition cables around.Cees Klumper wrote:My money is on misfire.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
ashitaka695 wrote:Is the "shake" something that happens while it's being driven or just while it is running? I have a 94 850 and while it sits and idles it will give a little vibration or shake. Mine is from the motor mounts needing to be replaced. Also while driving it starts to shake going over 70 I'm pretty sure its the bushings and tie rods. These are a few things on mine that causes the little quirks.
If the engine shakes enough for someone to park it and not to drive it, you know it's super serious shake. Could be misfire, could be bad plug(s), could be no/low compression, could be at lot of things. Would "I" go look at the car and do some testing? Sure. I can put engine/transmission/whatever in. Would I suggest someone wanting a project to look at the car? Sure, if they are capable and willing to change an engine for worst case situation. Anyone less than that, no.ChadLee wrote:Suddenly the car started shaking and she parked it and did not look back.
PS, you should really change those mounts and fix whatever else is wrong with your car.
Sommerfeldt wrote:Or someone switched the ignition cables around.
Someone "suddenly" switched the ignition cables? I don' think so.ChadLee wrote:Suddenly the car started shaking and she parked it and did not look back.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
Sommerfeldt
None of us have seen the car. Or felt the shake. So just how "super serious" it is, is guesswork for all of us. Same goes for how "suddenly" this happened, and what led up to it. Fact is, it can be a couple of bad plugs. Or someone switched the cables around because of whatever. Or, it could be a lot of other things.tryingbe wrote:Someone "suddenly" switched the ignition cables? I don' think so.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
tryingbe
Every thread on every car forum is a guess work for everyone who can't touch the car.
I hate repeating so I'll just leave this here, I'm out.
tryingbe wrote:Could be misfire, could be bad plug(s), could be no/low compression, could be at lot of things. Would "I" go look at the car and do some testing? Sure. I can put engine/transmission/whatever in. Would I suggest someone wanting a project to look at the car? Sure, if they are capable and willing to change an engine for worst case situation. Anyone less than that, no.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- 2076 Views
Last post by volvolugnut
- 764 Views
Last post by sek
- 1158 Views
Last post by oragex
- 2479 Views
Last post by Clemens
- 2254 Views
Last post by dpayne20
