Axles rebuild update.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
According to Marty @ Raxles he will rebuild non turbo axles if you provide the core. Center bearing has to be intact and usable if you are rebuilding the right side axle. He no longer does turbo axles in view of the prohibitive cost of the CVJ's. He says he has lots of NA components available and will therefore rebuild those if you supply a core. I didn't ask him anything about models there than 850. So, no more 850t rebuilds! He did say however that the NA axles are fine to use though theoretically less robust, so it looks like NA axle on 850t will be the only option through him. Otherwise, whatever else is out there.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Good information. Thank you.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
FYI,
When I bought the car a few years ago, after checking records, the local Volvo dealer used a standard N/A axle in my 1998 GLT S70.
Zero issues using N/A axle in Turbo model.
In retrospect, Volvo should have used the same axle for all models (N/A, GLT, T5), it makes more simple for everyone.
But the Swedish engineers have a way to make things complex!
wheelsup
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
I bought this one last year for $56 from Advance Auto Parts locally.
https://www.amazon.com/GSP-NCV73503-Ass ... 827bddbe3a
So far so good, it comes with a lifetime warranty, kept the receipt and UPC just in case. It gets the job done.
I considered Raxles but needed a turnkey same day thing and that wasn't going to happen.
I figured worst case is the axle goes back to AAP and they refund me my money, and I got a year or two's use out of it. As far as I could tell online, you kinda roll the dice with any imported axle if it isn't OEM.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
wheelsup wrote:I bought this one last year for $56 from Advance Auto Parts locally.
https://www.amazon.com/GSP-NCV73503-Ass ... B001B09YSM
seems the link doesn't work..
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Link fixed in Wheelsup's post above ^
Also -> Amazon link
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
cn90 wrote:FYI,
The axle size/design is based on the rated torque; thats why they are different. N/A may work fine but it will have a shorter life; especially during wheel spin then a large amount of hook up which causes lots of stress.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
polskamafia mjl
Has thanked: 19 times
Post by polskamafia mjl »
cn90 wrote:In retrospect, Volvo should have used the same axle for all models (N/A, GLT, T5), it makes more simple for everyone.
The only way this makes sense is if they use the turbo axles on all models.
Post by cn90 »
Not really, the dealer installed the N/A in my S70 GLT, zero problems during the last 60K miles.
@mecheng, I understand each engine has its own torque, my point is the difference is not that much, why Volvo engineers could not develop an axle that fits all 3 engines? That makes the catalog more simple to manage. If you look at the N/A axle, the diameter is quite beefy, it can handle Turbo engine.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
cn90 wrote:Not really, the dealer installed the N/A in my S70 GLT, zero problems during the last 60K miles.
Good to know, but so far we have a sample size of one. There are a lot of P80 turbo cars out there. Many with larger turbos than your GLT. And yeah, those dumb engineers, why didn't they just look at it???
The turbo axles also have a different (bigger) outer CV, FWIW.
EDIT: Come to think of it, you can definitely find posts about axles snapping, even Volvo ones. Hmmm ...
