I change new turn signal switch , I change all the bulbs, Hazard work Fine ,not turn signal one bling and die.
Can somebody tell me what can be wrong I can't find the flusher or turn signal relay.
David
1999 V70 turn signal problems
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You need a new Hazard Light switch - That's where the flasher unit lives.
Pull the radio, ( Don't unplug it unless you have the code!), reach up and
push it out from behind. Swap in a known good one. Done.
