Hi guys can an earlier s40 v40 engine be fitted to a 1.8 2005 s40 engine code b4184s11 I want to fit engine with code b4184s2
Thanks in advance
can an earlier s40 v40 engine fit 2005 s40
- Has thanked: 17 times
- Been thanked: 35 times
No, I personally would not try it- just to many variables including how the engine mounts, not even going to the incompatible computer in the newer car with the older style, etc...
- kcodyjr
- Been thanked: 23 times
+1 more of a pain in the butt than it's worth.
It's theoretically possible, by swapping over all the sensors and whatnot, and sometimes you have to weld/drill new hardpoints.
Fundamentally it'll be the same engine, but many many details will have incompatibly changed.
5 others that came and went
I've rebuilt engine but it has a huge drop in power when it gets hot any ideas please it's had new valves and stem seals and rings fitted as it was down on compression on cylinder 1 due to a broken valve and it was using oil I'm stumped I've cleaned egr but no difference new plugs air filter oil ect it sounds great and runs fine till temp hits half way then it feels like your towing the titanic behind you
- 1770 Views
Last post by volvolugnut
- 1185 Views
Last post by alschnertz
- 12 Replies
- 3701 Views
Last post by JimBee
- 535 Views
Last post by Jodyson
- 1209 Views
Last post by lummert
