I just bought a nice 2002 S40 with only 55K miles. Battery needs to be replaced. I have a good battery from another car that has 350CCA rating. Stock battery has 600CCA.
Other than the obvious risk incurred of difficulty starting in subzero temps with the 350CCA battery vs. a 600CCA battery, Can this lower rated battery be used in this car without creating some other electrical-related issue?
Thanks in advance for any insight or advice.
Ray
12V Battery for a 2002
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I don't think there will be any issues.
Try it. What do you have to lose?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
raybythelake
- Year and Model: 2002 S40
My default mode is "jump right in and do it", but I was trying to use the collective noggin before pulling the trigger. LOL. I'll probably just do it unless I get a sudden onslaught of "you'll fry your ECU" posts.
Ray
Ray
- Has thanked: 17 times
- Been thanked: 35 times
Tell us what you find out...I'm thinking that even in the summer, that's not going to be enough cranking power. I'd just run jumper cables to your own cables to begin with instead of lifting out and in your car to see if it works. Is the size relatively similar?
raybythelake
Yes, fairly close. I'll keep you posted on results.MadeInJapan wrote:Tell us what you find out...I'm thinking that even in the summer, that's not going to be enough cranking power. I'd just run jumper cables to your own cables to begin with instead of lifting out and in your car to see if it works. Is the size relatively similar?
- 2992 Views
Last post by 93SCMax
- 930 Views
- 734 Views
Last post by esl_97_850_T5
- 691 Views
Last post by hockeyjake1997
- 886 Views
Last post by regent
