Hello All
I took my car to a local goodyear auto shop to get the alignment done on my 1999 Volvo S70. I told them to check the brakes also and they told me that the Front left caliper is bad and will need to be replaced as soon as possible. They gave me an estimate of $200 with parts and labor to replace it with an after market one. I have heard some people say that who need to replace both of the calipers at once. They right side one is working just fine so do I still need to replace both of them. Also if I replace the calipers do I have to flush the brake fluid also.
My front left caliper is bad, Need Advise.
- Been thanked: 504 times
- Get a rebuilt caliper from NAPA Auto for $49. LT warranty.
This is what I did: a rebuilt caliper and for the opposite caliper, I rebuilt it using the kit (see link below).
- By this time, your car will need new hoses.
https://www.matthewsvolvosite.com/forums ... =1&t=37721
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
I rebuilt both of my front calipers years ago. Job was easy and parts very reasonable. I live in Tx though, not IL so nothing was rusted.
M1 10W-30 HM
M1 10W-30 HM
- Been thanked: 4064 times
You can replace one as long as they don't come loaded - i.e., with brake pads.
I did one at a time on the T5 and had to put the car up again 6-9 months later, though.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
When I did front calipers and brake lines, the hardest part was removing the brake line from the upper clip. I'm in MI, we salt our roads here (not sure if they salt down in Naperville), so things get pretty rusty. Anyways, I ended up using vice-grips instead of a box wrench to deinstall. Make sure you don't twist the steel lines while disconnecting.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
AhmedS70
- Year and Model: 1999 Volvo S70
FCP Euro has one for $36.99 on sale for a remanufactured one. Thinking of buying that one.
https://www.fcpeuro.com/products/volvo- ... emi-loaded
- Has thanked: 2197 times
- Been thanked: 1850 times
I have used Cardone re-man'd units several times with no issues.
- Has thanked: 17 times
- Been thanked: 35 times
Not sure I trust a tire shop with your Volvo.... a friend of mine recently went to a "Free Service" tire shop for tires and they talked her into all new calipers, rotors and pads and Zinged her for over $1200. I asked if she got the old parts back? She did not. I asked her if there were any problems with her brakes before this? She did not know as the car seemed to drive fine. I suspect that actually absolutely nothing needed to be replaced. I was hot headed about this and encouraged her to call me before any service is rendered on her car again. These places are notorious for fixing things that don't need fixing and also charging for and "replacing" things without sometimes even doing the work.
AhmedS70
Ok I bought the Cardone Left caliper from FCP. I also bought the brake line hose and the brake fluid since the brake fluid will have to be flushed anyway. I much labor can I expect to pay a mechanic for this job.
- 15 Replies
- 6406 Views
Last post by wizechatmgr
- 1524 Views
- 2071 Views
- 4190 Views
- 879 Views
