1999 OBD code P1073 ECM1100. Outside air temp sensor Topic is solved
Garaba
Year and Model: 1998 V70 XC
Post by Garaba »
I need some help. Volvo 1999 V70, runs great. But I can not get the sucker to pass emissions, I have a check engine light and the code P1073. I can not find anywhere what that code means at all.
It is also the code that is failing me at emissions. When I clear the code, it will come right back in about 20 seconds.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Garaba
Post by Garaba »
1999s have secondary MAF sensors?
misha
Post by misha »
Where in the link did you read "secondary maf sensor" :?:
Maf on your car is attached on airbox just like on all other models.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Probably a bad MAF sensor. Which seems odd to me since you say the car is running fine.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
http://www.obd-codes.com/sitemap.php
Save the link, it comes in handy.
bmdubya1198
crlande wrote:http://www.obd-codes.com/sitemap.php
It does. All you have to do most of the time... it'll avoid lots of threads asking about codes!
Garaba
Post by Garaba »
In this case the site was wrong. Since the p1073 was in the custom manufacturer code range.
For a 1999 Volvo it's the external air temperature sensor. I broke down and narrowed a laptop with the Volvo software on it.
Has thanked: 1609 times
Been thanked: 4064 times
What was the ECM code called off with VIDA?
Garaba
Post by Garaba »
ECM-1100, visually verified as having the wire ripped out when I curbed it sometime in the recent past.
