Hi All, 1995 Volvo 850 na
I cant get past the code word "How many signs on the website www.volvo-forum.de. ? I am trying to get the Brick-diags program to access Volvo specific codes. Does any 1 know any place else to get that. I'm also looking at the Total Car Diagnostics VAG OBD2 Diagnostic Scanner Tool lk. VAG-COM Software VCDS
toad obd1 & 2 program & cable. Any 1 have experience with this program?
Thanks in advance.
Jack
problems w getting Brick-diags, Toad any good?
adventurer2112
- Year and Model: 95 850 na
- Been thanked: 7 times
adventurer2112
HI, I am able to read the the OBD1 and 2 codes, which are not specific enough to determine why my auto transmission is not shifting above 3rd gear. I get the flashing arrow, etc. I have changed out sensors due to specific codes generated, But the p0730 and the a2 322 keeps repeating, but does not give enough specific info. I have used the Auto Transmission self diagnosis specific item testing circuits. Those say all Tranny solenoids are working, etc. But when driving they do not.
Im not sure dropping the tranny pan & replacing the TC solenoid & valve body will take care of the shifting problem.
I am hoping Brick-diag free or TOAD would give me Volvo specific code info.
Tia
Jack
Tia
Jack
adventurer2112
Hi Tryingtobe,
Thanks. I did 5 drain and fills. Shifting got better, but wouldn't shift above 60, so flashing arrow would come on. Then put 2 tubes of Dr. Tranny eliminate TC shudder. Shifting got much smoother, no flashing arrow at 35mph, but would start flashing when shifting above 60 mph. Did a Lubrigard tranny flush, complete flush. Back to problems shifting around 35 mph and above 60 mph. Sounds like I will need to find a low mileage used tranny & a shop to install it. Or look for a manual 850.
Thanks again, any thoughts on the flush results or ideas?
Jack
Jack
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
When the transmission is slipping, rarely will any fluid change will make it better for any length of time.
I put in a manual transmission myself since I couldn't trust a 200k automatic transmission.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
Sadly, I too support the paths forward for an 850 with an auto trans is to go manual or offload the problem child and call it a day.
That would be my route should my trans decide to kapoot.
ugh smh 850 Turbo fridge
adventurer2112
Reply solved but not answered.
Stripped the 95 of many good parts and scrapped it to pick and pull junkyard. Bought a 98 S70 with 110 K
Jack
Jack
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
For future use...
1. As far as Brick-Diag Free v0.0.6.6 goes, it probably would have reported the 3-2-2 error (like your A2 322), except that it would probably have given the English explanation "Gear 2, incorrect ratio". At least that's how Brick-Diag Free reported the 3-2-2 error on my 97 850 T5. Note: Brick-Diag uses a cable like Vol-FCR uses (not an ELM327 tool).
2. I have no idea if TOAD could have been coaxed into reading the Volvo specific codes of your transmission (prior to scraping). Note: TOAD uses an ELM327 tool (not a cable like Vol-FCR uses).
3. volvo850diag reports the following, since the 322 error can be associated with either P0732 or P0730.
AT-322 -- Gear 2, incorrect ratio [P0732] / Alternatively, on earlier models: Gear Ratio Info Incorrect [P0730].
4. Further diagnostic aids:
a. "auto trans diagnosis.pdf" in the 1995 Volvo_850.zip download at MVS has a section on "DTC 322/P0730: GEAR RATIO INFORMATION INCORRECT".
b. OTP Volvo 850 DVD documents relating to your particular 850's transmission. If I had the problems you've described, I would have studied the appropriate Power Transmission document on this DVD thoroughly for clues.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- 2794 Views
Last post by Sommerfeldt
- 26 Replies
- 5245 Views
Last post by rguzz
- 20 Replies
- 2978 Views
Last post by dspran
- 15 Replies
- 2122 Views
Last post by BlackBart
- 708 Views
