smoking dip stick new pcv system
- Has thanked: 311 times
- Been thanked: 817 times
First thing to check when that happens is for leaks or mis-connected hoses.
- is the intake manifold seated properly?
- are the two hoses on top of the oil trap switched, or hooked up the right way?
- are all the hoses hooked up?
Also, did you clean out (or at least check) the ports from the oil trap into the block?
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
I'd also consider a pinched hose. This sounds a lot like vacuum isn't reaching the crankcase.
5 others that came and went
