Does anyone know the thread pitch and size of the spark plug cover bolts? I have 1 stripped out hole that I need to repair with a helicoil.
Thanks!
Spark Plug Cover Bolt Thread Size Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
I don't know the thread pitch without checking but the next question you will get is: do you mean spark plug cover (plastic piece, 6 screws) or cam cover (aluminum, 40 bolts)?
If it's really the spark plug cover, you may want to just get rid of it.
Spark Plug cover. Black plastic sits on top of the engine and does nothing.erikv11 wrote:I don't know the thread pitch without checking but the next question you will get is: do you mean spark plug cover (plastic piece, 6 screws) or cam cover (aluminum, 40 bolts)?
2000 V70XC 160,000mi.
M6 - 1.0
- Been thanked: 504 times
I removed the cosmetic cover years ago and stored in my garage.
Have not touched the cosmetic cover for > 10 years.
The other day, I replaced the spark plugs, WITHOUT the cosmetic cover, it was a breeze!
So yes, get rid of that useless thingy, it does nothing but trap heat.
Not to mention when you wash engine, if you are not careful, water gets into the spark plug hole w/o you knowing about, ask me how I know!
PS: Even with one stripped hole, you can leave it alone. The remaining bolts will hold that useless thingy.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
OP even admitted its useless. He just wants an answer to his question.
mecheng
- Has thanked: 15 times
Is it useless? It keeps heat away from the charge pipe and directs it to either end of the cover.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
It is a "show room" thingy.
Many years ago, Volvo didn't do that.
Over the last 20 years, car mfg's put the cosmetic cover on (BMW, MB, Honda, Volvo etc.) simply b/c customers walk into the show room expecting "a nice look under the hood".
Good for marketing but useless and cumbersome when it comes to repair.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
it is NOT useless. How else would you know how many valves you've got
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1226 Views
- 3004 Views
Last post by Roger_850T
- 11 Replies
- 19422 Views
Last post by volvolugnut
- 14 Replies
- 1784 Views
Last post by EngineeringBloke
- 3876 Views
