I have a completely batshit crazy idea that I need some input on. Last year my beloved 850 turbo wagon was caught in a tornado and received some body damage that appeared minor but m insurance totaled it and revoked the option for a salvage title. Everything mechanical and electrical is in working order. I am basically looking for a parts vehicle that is a shell or has a trashed engine. I would like to put the guts of my 850 turbo into another turbo or non-turbo wagon. My question to you is can I put my 850 engine (and all of its components) into a V70? I ask this because my area seems to have a lot more V70s available that are parts cars than 850s.
Thanks, -Z
850 guts in a V70
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
You can only do it with a 98 V70 Turbo as a direct "drop-in" if you use the fuel rail/pressure regulator/injectors off the V70.
99 and up have VVT. N/A, just no, too much wiring work.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- ZionXIX
Hypothetically if I bought an empty shell, are the interior components compatible as well? Seat, dashboard, headliner...etc?tryingbe wrote:You can only do it with a 98 V70 Turbo as a direct "drop-in" if you use the fuel rail/pressure regulator/injectors off the V70.
- Has thanked: 312 times
- Been thanked: 818 times
Most of the interior is different. The 850 stuff will not swap straight across into the V70. OK the headliner may, front seats you can make work, dashboard possibly with modification. I have read of a couple a V70 dashes put into 850s.
- 1535 Views
Last post by volvolugnut
- 940 Views
Last post by woodchopper
- 6418 Views
Last post by esl_97_850_T5
- 1175 Views
- 1570 Views
Last post by erikv11
