My 2004 XC90 won't turn over
vonvon12
Year and Model: 2004 XC90
Post by vonvon12 »
I recently ran out of gas.in my 2004 XC90. I put 2 1/2 gallons in it and it will not start. Do I need or can I perform some type of reset. I check to see if gas was flowing and it is but it won't turn over. It was running great before I ran out of gas. Please help...
finding41
Post by finding41 »
Is the battery dead form trying to start it while out of gas?
I'd add a little more gas and charge the battery or get a boost.
Always check your fuses first.
Good luck
vonvon12
Post by vonvon12 »
Thanks
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
What happens to the lights when you try and start it? Do they get dim, or not even come on? Did you try cranking for a while when it ran out and wore the battery down? If yes, that sounds like a dead battery which you'll need to rectify (charge or replace).
How do you know you now have fuel flowing if it doesn't crank? If the battery is dead, the fuel pump won't run and you won't get any fuel. Also, if the engine isn't cranking, it won't start the fuel pump.
I could see the scenario where running out of gas could cause the fuel pump to overheat (no gas to cool it) and fail. But that would give you a crank-no-fuel symptom.
How sure are you that it was out of gas? Some sort of fuel blockage or pump failure might feel the same way, but wouldn't be fixed by just adding gas.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
