I am trying to determine if my camshaft position sensor is indeed bad. Can anyone tell me what the resistance should be between 2 of the 3 pins on the sensor? I took it off, no obvious defect... but resistance is infinite between any 2 of the 3 pins.
1994 850 NA
It's cranking, getting fuel... won't fire.
Thanks!
Camshaft Position Sensor
I have my working sensor pulleddoing the head gasket. This is not going to belp you much. Mine has open circuit between all pins. Also checked each pin to the positioner body and all pins are open as well. Tried several ranges on my meter with the same results. I had to replace mine a while back and I don't remember how I isolated it to the position sensor. I did buy one of the aftermarket sensors that was a lot cheaper and it has performed well fo quite a while.
Hope this helps. If it was me I would replace it since the car will not start if it is defective.
Al
Al
- Been thanked: 504 times
Or get a CPS from local junk yard to test.
There is a wiring diagram somewhere in forum, you can search for that.
Try this youtube video by Robert:
I just double checked that I am getting no spark.... and for fun I tried a noid light to find out that I am also getting not injector pulse...
2003 V70 Estate
2005 XC90 AWD
1994 850 Estate
1991 940SE Estate (RIP)
2005 XC90 AWD
1994 850 Estate
- 2792 Views
Last post by Luzanov345
- 1637 Views
Last post by cn90
- 624 Views
Last post by jackissocool
- 909 Views
Last post by cBobs94850T
- 1202 Views
Last post by Ozark Lee
