1998 V70 200,000
Speedo + Odo stopped at 175,000
When ever I give the engine gas whether its just to roll forward to get closer to the white line at a red light or "punch it" my AC dies, also she seems to stall when executing a "rolling stop" but the Kick back up after the coast at low speed. Just cleaned my MAF with CRCMAF cleaner to no avail, alas to the idea of a simple fix. The AC blows snow out the vents when its running but will only run after i hit the brakes, and if i coast in Drive it will in 10-15 seconds cut off HOWEVER if i flick (automatic transmission) it from Drive to Neutral it will remail on till i put it in drive and accelerate.
Please help its hotter than a jalapeno here in Miami in summer!!!
Problems with MAF, AC, causing AC to die when i put the pedal to the metal.
DavisonDudeDivision
- Year and Model: 1998 V70
Probably a dying AC clutch..check the AC clutch gap by searching for ' bread clip fix'
- 17 Replies
- 5518 Views
Last post by mecheng
- 2912 Views
- 1238 Views
- 11 Replies
- 2149 Views
Last post by bmdubya1198
- 18 Replies
- 3556 Views
Last post by beantown
