2005 S60 2.5T Cooling Fan
K.J.
Year and Model: 2005 S60 2.5t
Post by K.J. »
I need help! We have a 2005 Volvo S60 2.5T. The cooling fan starts up when we start the engine and goes off when we shut it off . When it running it very loud. Since the fan been doing this the engine light is on. Can someone help me to fine what is the problem please? :D
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
You need to start by pulling the codes. An AutoZone scanner will suffice. Post the results back here.
Very loud does sound like its bearings are beginning to fail. But find out what that CEL is about before you go buying parts.
5 others that came and went
Has thanked: 1609 times
Been thanked: 4065 times
I've noticed a peculiarity in my 1999 that when my MAF is disconnected the fan runs full time but get codes first, as the man says, diagnosing these cars by symptom isn't productive
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
If the fan itself is OK and you can turn on or off via the diagnostic scanner, then you have a problem is likely with air conditioning. Check the pressure in the air conditioning system. In my car, I temporarily emulated the signal of pressure sensor for conditioners system and my fan was not working.
neworleans
Year and Model: 2007 S60R
Post by neworleans »
You may need to replace the fan which is very easy.
