service light/speaker
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
catchthespirit
Post by catchthespirit »
Hi, I have a '91 740, and I just had the oil changed, but the service light was never reset. If anyone can tell me how to do that, that would be great.
Also, my front left speaker seems to work intermittantly - it will sometimes pop on if I go over a bump, but most of the time it's dead. Is there any way I can get in there and try to fix that? If so, what would I look for? Thanks. :)
wojeepster
Post by wojeepster »
The service light is reset by a plastic lever on the back of the speedo. It is hard for me to reach, i have big hands. Push in. I had the same thing with my door speaker. On my you just pull off the cover then remove the 4 screws. One of the wires was disconnected. If your wires are connected you might check the rubber bellows where the wires pass into the body down by the door hinge. A wire may have broken there. Sometimes the speakers rot. This will be obvious when you look at it.
