I just replaced my 02 with an 06 V70 due to issues on the ETM. So the car we just bought have some fault codes that I need help with to investigate:
CCM -0060
CCM-0062
CCM-0063
CCM-0070
CCM-DD12
CCM-DD30
CCM-DD31
CEM-8F12
CEM-8F1D
Is there someone that has any good ideas to where I should start my investigation of these errors?
(the break issue is going to be repaired by seller next week.)
Need help with error codes Topic is solved
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Try to go through diagnostic flow charts for BCM and CEM: http://xemodex.com/us/diagnostic-flow-charts/
The BCM issue is the sellers responsability to fix since we just bought the car. But do you think that the CCM issue might be caused of that aswell?vtl wrote:Try to go through diagnostic flow charts for BCM and CEM: http://xemodex.com/us/diagnostic-flow-charts/
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
As for BCM only issue is wheel sensors. But details needs to be posted. That maybe and very old issue and can be ignored.
CCM There is issues with seat heater control modules and some damper motor.
ECM has issue with thermostat that is cause of BCM-0100.
UEM faulty siren module.
CEM current issue with headlamp adjuster motor
SAS faulty steering wheel sensor. Causing BCM-0115 and BCM-0148
All yellow codes needs to be checked for details and counters. Without this information they are useless.
And all these codes are not software related.
If you have questions about Volvo firmware ask me. I may know an answer
doublebug wrote:As for BCM only issue is wheel sensors. But details needs to be posted. That maybe and very old issue and can be ignored.
Thanks for reply. Will see after wednsday what happens since alot of these faults is going to be fixed by seller.
doublebug,do you think that replacing the seat heater control module might be enough to get the seat heater working again?doublebug wrote:As for BCM only issue is wheel sensors. But details needs to be posted. That maybe and very old issue and can be ignored.
- 3162 Views
Last post by 2001downunderxc70
- 797 Views
Last post by Ozark Lee
- 2750 Views
Last post by alemao4100
- 616 Views
Last post by happikoto
- 2835 Views
Last post by aswresm
