Strong smell of gasoline in 1997 850GLT
digitalwizzard
Year and Model: 1997 850 GLT
Post by digitalwizzard »
My 850 GLT has a very strong smell of gasoline from the front of the vehicle when it is sitting.
It has been parked outside this week in 100+ degree weather.
It runs well and is not leaving puddles of gas on the ground.
Clearly it's some kind of evaporative leak
Could it just be the heat or could there be some potential hoses..etc disconnected somewhere?, where would you begin?
Also can anyone direct me to a source for diagrams and hose locators so I have a notion of where to look
I know older engines that were just pistons and distributors but these things are computers and plumbing......
I need help on this...
Thanks in advance for your assistance
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Is the gas smell from the front or back? If it is the front start at the fuel rail. If it is the back I would suspect a hose on the top of the tank.
digitalwizzard
Its in the front
Has thanked: 1609 times
Been thanked: 4064 times
It's either a loose hose on the canister ( annoying) or raw gas getting out ( dangerous)
If it's really strong I would look at the fuel pressure regulator ..follow the vacuum hoses to a dish near the firewall side of the engine , pull of the hose and sniff for fuel
The diaphragm breaks and let's fuel get sucked in to the manifold in excess.
Park vehicle until you find the source.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I summarized all potential fuel leaks in a DIY.
See the post from Nov 28, 2013:
https://www.matthewsvolvosite.com/forums ... =1&t=60269
