Timing Belt - 2006 S60 T5 stopped running while driving
blackmoreb
- Year and Model: 2006 S60 T5
2006 S60 T5 stopped running while driving. Car just went dead. Towed it to a shop who said broken timing belt and wanted $2500 to repair. Parked it and bought wife a new Volvo. So now I'm in the process of pulling the head to see how much damage to valves and pistons. Pulled timing belt cover... and the timing belt is NOT broken. It looks damaged... but still solid. So why did the engine stop?
Reason: Clarified title
JeffHicks
- Year and Model: 1989 240 Wagon,
It likely skipped some cogs.
If you get it dismantled far enough, it's easy to check the timing and see if that's what happened.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
zanzabar
- Year and Model: '07 V70, '84 245
- Has thanked: 1 time
- Been thanked: 4 times
Maybe the tensioner died and it skipped a few teeth on one or both of the cam pulleys. Let us know what you find when you pull the head.
Replacing or rebuilding the head should be easy enough (http://www.ebay.com/itm/VOLVO-2-4-2-5-D ... 0887573476).
But note the procedure for resetting the VVT cams is a bit of a chore.
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
- 15 Replies
- 4477 Views
Last post by mrbrian200
- 62 Replies
- 17729 Views
Last post by Shanestrait
- 74 Replies
- 20248 Views
- 2215 Views
Last post by Sixthandredline
- 2419 Views
Last post by Ou2mame
