S70 headlights
rnelson1020
Year and Model: 1998 S70 GLT
Post by rnelson1020 »
Replaced headlight wiring harnesses due to age and heat deterioration. Now headlights do not work. Corner amber lights work. Turn signals work. Fuses and relay look ok. All electrical connections rechecked and ok. High beams flash when I pull the left stalk on steering stalk. Any ideas?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The next logical place would be the headlight relay. How bad did the old harness melt? Bad enough that it shorted out?
harryhendo
Year and Model: 940, 855, S70, V70
Post by harryhendo »
I would pull the wiring connector off the low beam bulb, and hook up a test light to the positive wire to see if you actually have 12v going to it. If you do, then I'd suspect the relay.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Maybe both low beam bulbs are burned out.
Has thanked: 1610 times
Been thanked: 4068 times
crlande wrote:Maybe both low beam bulbs are burned out.
Be careful you don't cut yourself on Occam's razor...... :D
crlande
Has thanked: 1 time
Post by crlande »
The razor gets duller over a lifetime, I can attest to that!.....
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I'd start with a meter on the low beam fuses with the key on
and the headlight switch turned up to the 12:000 position.
Locations 21 & 22. Check the two nubs in the top of each
fuse while it's still in place. They should be hot at both ends.
If you have power getting through the fuses, check the stuff
that you touched before you start shotgunning other things.
9 times out of 10, if it worked before you got in there,
something happened where you were servicing the vehicle.
Is there voltage on pin 2 of the 4 pin headlight connectors?
Where'd the new harness's come from? New or used?
Did you confirm that all the wires line up pin for pin at the connectors?
Do they meter out pin for pin?
Do the headlights work if you put the old harness's back?
Here's a visual:
98 S-V 70 Headlights.pdf
(443.19 KiB) Downloaded 136 times
98 S-V70 Fuse Locations and Legends.pdf
(678.65 KiB) Downloaded 122 times
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
:D :D
