what part is this - 1998 v70t5 Topic is solved
noev70t5
Year and Model: 1995 850 TURBO
Post by noev70t5 »
If I could get some input on this attached photo,
This is taken to the right of the engine to the left of the airbox
There is a bit of leakage coming from the part that is the darkest in the picture (almost dead center) and looks as if oil is leaking from it?
Can someone help with what it is so I can gauge when or if it should be fixed
Thanks as always!
2002 s60 Base - 215k - KIA [08-2014]
2000 s70 Base - 170k - Traded in [2015-16]
1998 v70 t5 - 232k - KIA [2016-2018]
2000 s70 Base - 180K KIA [2018-2018]
1995 850 TURBO - 77K [2019-]
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
That part is connected on transmission and it looks like it's reverse light switch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
noev70t5
Post by noev70t5 »
This guy is a switch? So the fluid should be transmission fluid?
misha
Post by misha »
Should be....i don't know what else should be on top of transmission housing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
I think it's the transmission speed sensor. Try changing the O-ring on it.
misha
Post by misha »
Could be....but doesn't look like one from that angle of view.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
noev70t5
Post by noev70t5 »
chrafael and misha, you guys rock! Thank you as i got the info I need. Using another picture where they pinpointed the TSS (you can see its to the right of the block and the left of a cone intake on another picture). It seems like an easy thing to tackle. Still without yalls help i wouldve had no clue where to start. Thanks again!!
