Hello! Recently our 2002 Volvo XC 70 has lost the ability to open the rear trunk hatch door.
Very frustrating as there is no key area on the outside or no handle on the inside to open the trunk.
Has anyone experienced this and if so would anyone have a fix?
Thanks in advance,
Stephen.
XC70 has lost the ability to open the rear trunk hatch
Stephen0523
- Year and Model: XC70 2002
Reason: Clarified title - please no all caps
TrstnBrtt
- Year and Model: 2006 XC9 2.5T
Look above the license plate holder, where you grab the handle to lift the hatch up, to the right is a circular rubber grommet. Pull that out and there is a spot for you to insert your key and unlock it.
If I paid attention to signs with little symbols I’d never find anywhere to park.
db130
- Year and Model: 2002 V70 T5
Do you hear and feel the hatch lock actuator moving the lock to the unlocked postion when you hit unlock with the keyless entry fob?
The hatch on my NA occasionally gets stuck and the trick to opening the hatch was to push the hatch towards the front of the car as you pull on the handle, as described here:
https://www.matthewsvolvosite.com/forums ... hp?t=18360
Re: tailgate will not unlock and open
Unread postby holler1 » Wed Jan 28, 2009 12:00 am
Try pushing in (forward) on the door at the same time you pull the release lever. Give it a quick hard shove in. That is how mine releases. It seems to free up the release somehow.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
Stephen0523
Good morning. I looked and there is no rubber grommet for a key and I tried pushing and pulling for holding the latch and also making sure the doors unlocked LOL but no luck.
JRL
- Year and Model: Several
- Been thanked: 16 times
You need a new or a good used lock. They fail, it's as simple as that.
Stephen0523
LOL, seems my 1989, Sunbird, 1984 Oldsmobile and 1974 Dodge Tradesman van have less problems
Might get a replacement lock before digging in there.
This solved it on my old 2008 V70. I could not open the hatch even though I could hear the motor apparently moving the latch to unlock it.
Go to just behind the metal plate on the outside of the door where you put your hand to reach into the lock. If you feel in there immediately behind the plate you will feel another (plastic?) plate. Push this forwards, towards the metal lever you would normally pull towards you to open the hatch. You will hear a slight click and you can then open the hatch normally. I think there is a linkage that fails to engage normally. This might be why one tip was to push the actual door, which might also re-engage the link.
It took me a little while to find this trick, then a few minutes squirting WD40 (other releasing fluids are available) into the underside of the lock while clicking the mechanism. After this it always worked as it was meant to, no need for new locks or major work.
Hope I have described what I did clearly enough, and hope it solves your problem.
Stephen0523
Thanks Vcaspar for the tip. Would it be possible for you to upload a video or some photos of what you're describing I should try?
Stephen0523
Hello. I got my new trunk release motor in today and installed it and it did not work which ruled out it is the trunk release motor mechanism. But the good news after some digging around and listening I determined it was a relay in the trunk and I just replaced it and everything is working solid! So now I have a spare trunk release mechanism. When I have time I will post steps that I talk and photos for anyone else having same issues.
- 1227 Views
Last post by zanzabar
- 1221 Views
Last post by oizdaman26
- 1132 Views
Last post by Vova585
- 1295 Views
Last post by configsys
- 1997 Views
Last post by PeteB
