But, I plugged in the 628, and the car started and ran fine. Then, after about 10 seconds, I got a CEL. Shut off the car, and found DTCs 335 and 444. The guy I bought the ECU from said it worked fine in his R, with no issues. I can't seem to find any good explanations for these two codes either, especially since the car runs, boosts, shifts great with it on the test run after I got up the courage to ignore the CEL for a little while.
Codes reset, comes back in 10-15 seconds after start. Swapped in original ecu - no codes. What tha fudge is going on?
I found a thread with the exact same issue in here from earlier, but that one didn't lead anywhere.
- S
