Seafoam
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I'm swapping out my spark plugs today and was wondering since I have them out, would it be wise to put a teaspoon or a few drops of seafoam directly on top of the cylinder. I have used it in the past through the vacuum tree, but never on this car I'm working on today. Any suggestions would be greatly appreciated.
Eddie g
Has thanked: 2207 times
Been thanked: 1852 times
I would caution doing that as it may remove all the carbon from the rings and you lose compression or end up with the lawnmower syndrome. Why not just add it to the gas tank and take it for a good run?
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
It's not advisable, through the vacuum tree and through the injectors it gets atomized. Too much could cause compression issues, I would just stick with the normal way of doing it.
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
dorvin
Year and Model: 1997 Volvo 850 T-5
Has thanked: 1 time
Been thanked: 4 times
Post by dorvin »
I normally just run a can through the gas each time I change my oil. I'm interested in running it through the vacuum tree, I'd have to drive out of the city to do it though, as if I'm understanding it correctly, it can really cause a smoke show.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Like Neil said, direct application in the cylinder could cause uneven cleaning, or degradation of your ring seal.
Through the intake on a warm motor allows a steam cleaning effect on your intake tract. Like easy-off in a hot oven. All the backside of your valves, where fuel treatment doesn't get.
To clean your piston tops and combustion chamber, cleaners through the fuel system.
Current Volvos:
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
I've never heard of carbon _helping_ the rings seal. This guy looks at
the pistons with a camera and he shows that pouring a small amount
in as the OP suggests was most effective:
Here he does it the usual way, again looking with a camera:
I'm nervous about pouring even a very small amount in the spark plug
hole but I have a feeling that it is most effective.
