Before I get started, I know this is similar to other posts, bare with me.
I've got a 1998 V70 AWD (2.4 turbo, of course) and the speedo didn't work, ABS and tracs lights are on. I changed the front ABS/speed sensors and the speedo works again, lights are still on. I changed the ABS module, the same thing.
Any suggestions? Thanks in advance.
1998 V70 AWD Topic is solved
- happy_dalek
- Year and Model: 1990 240 DL
1990 Volvo 240 DL
B230FT + Izuzu NPR Intercooler
Holset HY35W
eBay BOV
Cut Springs
28mm Front Sway Bar
25mm Rear Sway Bar
Stock Chipped Turbo ECUs
Future Plans:
Microsquirt
Holset HY35W
eBay BOV
Cut Springs
28mm Front Sway Bar
25mm Rear Sway Bar
Future Plans:
Microsquirt
- Has thanked: 2205 times
When you changed the module (not trying to be smart here) did you get a new one, reconditioned (if so where from) or did you do it yourself?
The wiring for the ABS module/pump can be a little fragile with age and can be troublesome to re-seat correctly.
- happy_dalek
Car was sold, not my problem anymore. Thank you for the reply, though!scot850 wrote:When you changed the module (not trying to be smart here) did you get a new one, reconditioned (if so where from) or did you do it yourself?
Bought the car for $400, sold for $2000. Went and picked up a '91 240 wagon.
1990 Volvo 240 DL
Holset HY35W
eBay BOV
Cut Springs
28mm Front Sway Bar
25mm Rear Sway Bar
Future Plans:
Microsquirt
Holset HY35W
eBay BOV
Cut Springs
28mm Front Sway Bar
25mm Rear Sway Bar
Future Plans:
Microsquirt
That is an extreme way of fixing a problem. Now we wait for the new owner to ask for help!
- happy_dalek
It was just too much of a hassle to try to fix. Now I've got a '91 245 that doesn't have ABS to worry about that runs and drives great.scot850 wrote:That is an extreme way of fixing a problem. Now we wait for the new owner to ask for help!
1990 Volvo 240 DL
Holset HY35W
eBay BOV
Cut Springs
28mm Front Sway Bar
25mm Rear Sway Bar
Future Plans:
Microsquirt
Holset HY35W
eBay BOV
Cut Springs
28mm Front Sway Bar
25mm Rear Sway Bar
Future Plans:
Microsquirt
- Been thanked: 4070 times
Pick us up in the 245 Forum!!
ABS on the P80 cars is easy to fix and usually solved by either reseating connector or Midwest ABS
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The '91 240 doesn't have ABS?
