A/C and REC light flashing?
theneedforswede
Year and Model: 1996 850R
Post by theneedforswede »
I just picked up my second 854R yesterday and noticed that whenever I start it that the A/C and REc lights flash for about 10-15 seconds. Is this something to be concerned about?
1996 854R "Astrid" White/Charcoal 16T, R mani, OBX turboback, ipd HD Endlinks, Koni FSDs, Eibach Prolines
Past Volvos: 95 Emerald/Tan 855T, 96 Primer/Charcoal 854R
Jazzer
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Post by Jazzer »
You've got a fault code in your ECC; could be anything from a seized intake fan (that's what mine is right now) to a stuck blower door to a faulty temp sensor. You can read the codes with a diy reader or have the dealer do it. Lots of info on here if you search the forum...
Has thanked: 1609 times
Been thanked: 4065 times
It can be really minor, like it is detecting a mismatch in the door and motor command - so it can be deferred, like wing crack inspection on an airplane wing.
