Fix poor range on remote key fob for S70
Waltazhaar
Year and Model: 1997 S70R
Has thanked: 6 times
Post by Waltazhaar »
Hello people,
I have a problem with my S70s remote locking range. I can just lock the car if I have the remote just next to the drivers door or next to the windshield. I've tried by changing batteries in the remote but it didn't help.
Is there any way of increasing the range/reception of the central locking unit by, for example, soldering a wire to the antenna of the unit?
I'd also like to know where the unit is located exactly. I've heard its a black box under the dashboard, on top of the instrumentcluster. Is this correct?
Has anyone done this already? I appreciate all the help I can get. :)
Kind regards
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
That suggests a problem with the transmitter, much more likely than the receiver.
Unfortunately, proving the theory requires a new remote. And dealer programming.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It sounds dumb but if you stick it under your chin and press the button the range will improve by about 300%.
BEJinFbk
Post by BEJinFbk »
Ozark Lee wrote:It sounds dumb but if you stick it under your chin and press the button the range will improve by about 300%.
Sure, but his range is far less than normal.
My '98 fob hits from 30 feet without the chin trick.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
My 850 manual says 5 meter range.
85 GLH, 367 whp
00 Insight, 72 mpg
Waltazhaar
I'm assuming the transmitters aren't at fault here as they both have new batteries in them and are equally bad when it comes to range. I have to hold them about 1 inch from the glass to make them lock/unlock the car.
BEJinFbk
Post by BEJinFbk »
If the euro version is the same as US, it's on top of the cluster.
There's no external antenna. Even if there was, extending the
antenna isn't going to fix a receiver with problems.
Waltazhaar
BEJinFbk wrote:If the euro version is the same as US, it's on top of the cluster.
I was thinking of opening the unit and clean plus resolder, and extending, the antenna inside the unit for better reception. :) Theoretically that should work. I just need to know exactly which unit it is.
kranz
Year and Model: '98 V70 NA stick
Been thanked: 8 times
Post by kranz »
Waltazhaar wrote:Hello people,
My spouse now has this problem with her 2004 V70, but a second FOB works with no problem. So in her case, the problem seems to be isolated to her particular FOB. I replaced the battery to no avail. However, I did notice that on her FOB, unlike the second FOB, the battery does not fit snugly in its receptacle. I suspect poor battery contact may be at fault.
Les is more.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I have the same problem, I notice it is worst when I am closer to downtown; I think all the radio waves interfere with the transmission.
My 850 doesn't have the same problem. I think extending the antennae would work if its possible.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
