Good call on this, definitely worth checking.echase76 wrote: ... Will also check wire routing sleddriver
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
1998 V70 Hesitation after Tuneup - Coil?
- Has thanked: 129 times
- Been thanked: 362 times
Re: 1998 V70 Hesitation after Tuneup - Coil?
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
gone: '96 NA 850 210k, '98 NA V70 182k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- Year and Model: 1998 v70 T5m
Thanks for all the tips folks. Fixed the FPR vacuum elbow leak and moved the coil wire well away from other wires. So far so good, but just a quick test run is all I had time for.
Do NOT want to declare this solved yet until we have some time to drive it around. If it comes back I'm planning on replacing the coil and fuel filter next.
Will keep folks updated.
1998 V70 T5m Silver/Charcoal - 150K
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 12 times
Update?
M1 10W-30 HM
M1 10W-30 HM
All was good for a while until recently and it started hiccuping again.
I'm going to recheck the coil for resistance, clean the MAF and make sure my wire routing is good. I have done some work off and on taking off the airbox and such and didn't make sure to be careful about coil wire routing.
