Hello
The power trunk botton that's on the driver side door does not work. I can only open the trunk from the outside using the key. Anyone know what the problem could be and what needs to be fixed or replaced.
Power trunk botton does not work.
Are you heairing the plunger in the back Move when you hit the button? You might need to two people and a quiet place to test this.
I've got mine all apart on my 1999 v70 so I've got plenty of pix. I'm not positive they are the same
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
power trunk button? Is that an S/V70 thing? I know, tbis is of no help to the OP, but satisfies my nosyness
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 2199 times
Most likely the wiring harness has a break at the hinge. I find the motors do go bad but rarely. The 850 lock only locks/un-locks from the fob, but the S70 releases. The S/V70 locks release the fuel flap and the trunk on the sedan, but on an 850 it just un-locks the item. In both case it is most likely the wiring that fails in the trunk issues.
Do you have this one or this a V70 1999 on thing??
This issue will be the same for all 98-00 S70's.
- 1221 Views
Last post by oizdaman26
- 1130 Views
Last post by Vova585
- 1382 Views
Last post by Joffwillson
- 12 Replies
- 7499 Views
Last post by viper69
- 1642 Views
Last post by cn90
