I am having a problem: when the driver's seat is moved on my 2000 V70, it trips the SRS light. This happened once before, and I had a local indy shop reset the light, which stayed off afterwards for at least a year. This weekend the seat had to be moved to accommodate a different driver, and it tripped the light again.
Does anyone have any suggestions for where to look? Having to pay $50 to reset the SRS light gets old fast!
2000 V70 moving seat trips SRS light
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
It sounds like a chaffed wire or a sloppy connector causing a momentary loss of contact which would set off your SRS indicator. If it only happens when the seat is repostioned I would inspect the wire harness from the floor through the seat.
- Has thanked: 2203 times
+1 to what kahl says. There are a bunch of wires under the seat that get bent every time the car seat is moves and become more fragile with time. Have a good look at the wires and connectors, and if necessary, dis-connect the battery and remove the seat to get better access.
Good luck!
Good luck!
- 1730 Views
Last post by darrylrobert
- 9069 Views
Last post by spue
- 24 Replies
- 5721 Views
Last post by bronco
- 27 Replies
- 28303 Views
Last post by cn90
- 1118 Views
Last post by jonnies
