2002 S60 2.;4T Rough Idle and Multiple Codes, (bad hose) Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
agloy63
Year and Model: 2002 S60
Post by agloy63 »
2002 S60 2.4 LPT
I suddenly have had an issue with rough idle. I have the following codes:
P0132 O2 Sensor Circuit High Voltage Bank 1 Sensor 1
P0171 System Too Lean Bank 1
P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
I also have P0300 through P0305 misfires detected.
I have visually checked for bad vacuum lines, not that I might have missed something, and have cleaned the MAF sensor. Any ideas out there are greatly appreciated.
zanzabar
Year and Model: '07 V70, '84 245
Has thanked: 1 time
Been thanked: 4 times
Post by zanzabar »
Probably that O2 sensor has gone bad, or needs to be cleaned, or the wiring to it is frayed, or the wiring connector needs to be cleaned?
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
look at the base of the injectors for fuel stains, they can develop air leaks,
tell tale sign is the dirt around the seals where they plug into the intake manifold.
agloy63
Post by agloy63 »
New and interesting. When the idle is really rough there is no power assist to the brakes.
zanzabar
Has thanked: 1 time
Post by zanzabar »
Keep looking for a vacuum hose gone bad, this brake issue points to problem with brake booster hose perhaps?
VW TDI refugee
1994 855 (sold)
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Pinch off the vacuum hose that runs to the aux vac pump and brake booster etc. and see if the idle smooths out.
agloy63
Post by agloy63 »
Turned out to be a very small, rigid vacuum line going to the manifold. Didn't see it due to it being inside a larger rubber vacuum line!
