hey everyone i have a north american 1999 glt s70. automatic it will not turn over but will crank i disconnected the fuel rail to see if the injectors worked they did and the car started for a brief second.
cheers for advice.
1999 glt wont start unless fuel rail is disconnected
fewthegooddude
- Year and Model: 1999 glt s70
- Been thanked: 4068 times
You may have flooded it and letting air in helped clean it out
Things to check
Engine coolant sensor ( ECT) near thermostat, check resistance and wiring
Vacuum leaks
Things to check
Vacuum leaks
- 1143 Views
Last post by racertim
- 1825 Views
Last post by IslandV70
- 1199 Views
Last post by shiloh51933
- 372 Views
Last post by misha
- 16264 Views
Last post by Richard99
