Volvo 850 GLE 20v - Radiator Cooling Fan
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I just had the same problem on my 98 S70. It turns out my relay was bad. First thing I would do is check to see if your fan works. Get yourself a couple alligator clips and put power directly to the fan. I would assume your fan probably works because of the mileage on your vehicle. From there you can check your relay. If you remove the middle plug of the fan relay (its under the passenger side of the radiator shroud) and ground one of the 2 prongs the fan should kick on. Also, if you turn on your air conditioner that should automatically turn on your fan. Hope this helps.
Has thanked: 2197 times
Been thanked: 1850 times
shaker_chi has a just completed thread on a similar experience:
https://www.matthewsvolvosite.com/forums ... =1&t=78274
This includes links to how-to info.
Good luck!
