Any input on the issue would be really appreciated. So far i was suggested to replace the torque converter, but it's a quite expensive part and labour isnt cheap also. So im kind of hoping it could be a less expensive issue
2004 S80 d5 2.4 Automatic transmission rpms fluctuate
Hi! Theres a problem with my car's transmission (presumably, may well be something else) where the rpm-s fluctuate when driving at constant speed. Also it does not happen with cruise control. I took a video of the symptoms
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
Hi,
Have you ever tried to rev it to 1500 rpm and keep it there when the transmission is on neutral and the car not moving, if it does the same then I don`t think you have problem with your transmission.
- 1939 Views
Last post by rerobin66
- 1153 Views
Last post by Krons
- 1754 Views
Last post by Dan79
- 1579 Views
Last post by jimmy57
- 4728 Views
Last post by RickHaleParker
