Hello,
I could use a hand figuring this out . The car had been running great, smooth driving, smooth shifting, and a nice purr on idle.
I have a 1994 850 turbo wagon. Wife was driving it last night and the car slowly lost rpms until stalled out. It did restart a couple of times but in a very rough idle it then lost rpms and killed each time. We had it towed to a mechanics lot, but I went out last night to retrieve the codes listed below is what I found. Also, at that point I started it up, it turned over no problem and I was able to rev the engine and it did sort of stay engaged, but was pretty rough and then if I let off the gas rpms dropped and it died, with traction control light and some other dashboard stuff blinking . In the recent past it has seemed like the PNP swtich was going bad, as I a few times I would need to move the shifter to get the car to start , but that hasn't happened in months.
Here are the codes. The front knock sensor and the preheat codes have been there for a couple of years, even after I replaced both O2 sensors. Could the knock sensor finally have faulted...I don't remember the rear knock sensor showing up before.
A1 - 1-1-3, 1-1-4,
A2- 5-2-1, 1-4-3, 4-3-3, 2-1-2, 3-2-5
A7 - 1-1-1
and then I swear I was in the right port for A3 - but got codes that don't seem to be on the list
2-1-3,2-1-4,1-4-1,4-4-3,1-4-2,1-4-4
Any help would be appreciated!
850 slowly lost rpms-will start- can rev- but idles and dies
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Clear those codes and see which ones comes back.
Here is the list of the codes:
http://volvospeed.com/volvo_repairs_how ... es_a2.html
"A2" Codes are pointing to both knock sensors,O2 sensor and memory fault which could point to bad ecu(which is unlikely).
The things which manage them are ecu and relays.Check MAIN fuel injection relay on fan shroud (grey one)under the hood and fuel pump relay.ALSO check for blown fuses in fuse box.ECU & TCU fuse should be #1,but check fuse list to be sure.
"A1" codes are transmission codes which are pointing out bad TCU(which is HIGHLY unlikely for both ecus to go bad)& p'n'p switch.
http://volvospeed.com/volvo_repairs_how ... codes.html
Bad voltage supply or bad ground could be the culprit at this stage.Does the alternator works properly and what condition is the battery and battery cables?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 504 times
1+,
I have the same experience (random stalling), turned out it was MAF.
New Bosch MAF solved the stalling.
But you need to check the usual stuff...air filter, fuel filter, plugs, cap, rotor etc.
- 15 Replies
- 5928 Views
Last post by Reys
- 1574 Views
Last post by j-dawg
- 860 Views
Last post by JLv70t5
- 893 Views
Last post by lummert
- 13 Replies
- 5360 Views
Last post by volvolugnut
