1998 S70 P0505, throttle body adjustment needed Topic is solved
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I was getting the dreaded p0455 code last week and replaced most of the hoses and the purge valve. Of course, I have driven my 98 S70 T5 about 150 miles since my repairs and now code, but now I have a pending p0505. The car idles very steady at 900 rpms and I don't hear any loping. I sprayed around the engine (vacuum tree, intake pipe, etc.) with some carb cleaner and didn't see any noticable change in idle. Any suggestions as usual are very much appreciated.
Has thanked: 1610 times
Been thanked: 4068 times
Thats an Idle Air control valve problem on a pre-1999.
When was that last cleaned?
shaker_chi
Cleaned it out when I did the PCV about 2 years ago. Will knock it out tonight and see what happens. Thanks Abscate.
shaker_chi
Just a follow up on my P0505 issue. I took out the air idle control valve and cleaned it out. Reset the ecu and got the P0505 after about 10 miles. I sprayed carb cleaner everywhere with no luck. Turns out the throttle body wasn't shutting completely. Adjusted the screw a bit and now I'm good to go. Drove it about 50 miles yesterday with no codes.
