Did you know? 🤔
What did you do to your Volvo today?
Has thanked: 221 times
Been thanked: 730 times
Trinidad & Tobago
Re: What did you do to your Volvo today? (now Sticky)
Post by abscate » Wed Jul 10, 2019 7:02 am
Chevy Vega was early version of Aluminum head and cast iron block...and the car we learned that if you overheat for more than a minute, the engine is done. Now we accept that, but the Vega got a bad rep for exploding engines. It was bad for many other reasons, though.
bmdubya1198
Year and Model: '98 V70 GLT
Has thanked: 28 times
Been thanked: 101 times
United States of America
bmdubya1198
Post by bmdubya1198 » Wed Jul 10, 2019 8:15 am
Well I'm certainly equipped for a sub-$500 P80 rally!
2000 V70R Venetian Red/Charcoal M56 Swapped 191k
2000 S70 GLT Mystic Silver/Taupe 2??k
2003 S60 2.4T Silver/Black 108k
2007 XC90 V8 AWD Sport Titanium Grey/Black 160k
1993 944 Base Beige/Beige 221k
1992 Miata Mariner Blue/Black 146k
1998 V70 GLT Black/Beige 193k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k- Never should have sold it
Need used parts? PM me!
Ocelot
Year and Model: 1998, S70
Been thanked: 6 times
Netherlands
Ocelot
Post by Ocelot » Wed Jul 10, 2019 10:46 am
So today I was at the diy garage where I changed the oil and filter, made myself a flash reader with the information gathered at the repair database of MVS and discoverd a few things to take care of before heading out for my second roadtrip through eastern Europe:
  • * The exhaust manifold has a little crack. I've noticed some more noise than usual, I expected a leak in the exhaust system, just not the manifold itself. Some brave soul tried to weld it and I remember from back at my car mechanic school days that welding cast iron is a bit tricky. I've found the crack just under the weld. Luckily I can buy a new manifold for about 150 dollars (German quality).
    * The cv boot on the right has a tear in it, nothing big, but I will fix that shortly because once that kind of grease is spun around the axle and surrounding area, it's a real pain to clean it properly (not to mention the damage to the cv axle).
    * The outer tierod balljoint has too much play.
So those three things are on my to-do list for the coming weeks.
Edit: I also checked the suspension of my S70 and I noticed that my front struts are on their last days. Anyone with some tips on which brand to use? And which to avoid?
Deus semper maior
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Wed Jul 10, 2019 8:39 pm
I've been happy with Monroe, Sachs, and Koni struts in P80s. Koni STR.T (orange) are my favorite, they are stiff without being harsh. I have them in my V70R and really like the ride. I have Monroes in my GLT, and they have been good for the past 2-3 years I've had them in there. Decent ride, but they're definitely budget struts (I paid about $70 for both struts and both rear shocks as well after a rebate vs. $205 for just the two Koni struts).
My cousin has Sachs in his S70 T5 and they're similar to the Konis, but a little softer, definitely geared more towards comfort. I would recommend these if you want an OE-quality strut (being that Sachs is the OEM).
brunocerous
Year and Model: 1998 V70
Has thanked: 34 times
Been thanked: 7 times
brunocerous
Post by brunocerous » Thu Jul 11, 2019 1:52 pm
One of my two sub-$500 candidates was towed away a couple of weeks ago. I'm hoping to register the other (a T5) in the next week. :)
I was going to suggest KYB, which rides well and isn't too expensive, when I realized the V70 in my driveway with a bad strut after a year is the one with the KYB. That might answer which to avoid.
1998 V70 T5, AT, project
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Mstrshkbrnnn
Year and Model: 94 850
Has thanked: 3 times
Mstrshkbrnnn
Post by Mstrshkbrnnn » Fri Jul 12, 2019 2:00 am
Today, I replaced rear cam seals and installed my newly purchased cam locking tool so that I could reposition the cam gears correctly so that the timing marks were where they should be according to cam position. Upon starting though, front cam seals starting leaking a bit, and under a stress test to break them in the pissed oil. Unlike the rear cam seals which were super easy to remove (just pried it out with a tiny screwdriver), the front were almost welded in. Robert diys trick didn’t work. Pb blaster only helped the intake cam. Exhaust cam got torched and hammered out with a screwdriver and hammer by my coworker before it finally decided to come out. It came to this very drastic approach bc nothing else seemed to be working and my coworker and I had been trying to remove this seal for the second day in a row already. As you’d expect, and as I did, when he hammered the cam seal out he gouged the sealing surface for the cam seal on the cam, and so the fronts are leaking, and the exhaust cam especially. Figured I’m just gonna need new cams, but that’s gonna have to wait a few weeks or so, and at least I’ve already got brand new seals, and the proper tool so I can be confident in my timing. Until then, I’m gonna try and keep my revs as low as I can and keep an eye on my oil level.
'94 854 NA 287k (bought for $400)
'98 s70 GLT 243k (bought for $250 currently non running)
'96 854R 173K (bought for $900)
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Fri Jul 12, 2019 8:29 am
Uhhh... that's not how you remove cam seals. I'm not at all surprised they're leaking. Hopefully you just damaged the cams and not the head/cam cover, just the cams will be easier to replace.
If this was for the 850, let me know if you need the cams. I have a set I can sell you.
These users thanked the author bmdubya1198 for the post:
Mstrshkbrnnn
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 5 times
France
Fiodor
Post by Fiodor » Fri Jul 12, 2019 2:52 pm
After finding out my PCV was clogged two weeks ago I finally did it with my brother in law today.
Took us about 4hrs of mechanics and 2 hours of running around trying to find a shop that had a vacuum line to replace the Evap lines that broke in half when I tried to remove them.
A huge thank you to @jblackburn for his guide!
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
wizechatmgr
Has thanked: 20 times
Been thanked: 51 times
wizechatmgr
Post by wizechatmgr » Fri Jul 12, 2019 6:59 pm
I believe they did this on the 2007 Dodge Caliber - their improvement was to use two thermostats - one for the block, one for the head.
1999 V70 XC AWD - ~183k miles
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Fri Jul 12, 2019 7:32 pm
Did the PCV on my cousin's '91 240 today. Holy crap... it makes the white block PCV look harder than a VW W8 timing job! Two screws, two hoses, and an o-ring. New flame trap to finish it off.
