Photo upload attachments are fixed. I broke them inadvertently last night.
What did you do to your Volvo today?
ZionXIX
Has thanked: 9 times
Been thanked: 46 times
Post by ZionXIX »
Change my wiper blades. The passenger wiper arm slipped out of my hand after removing the old wiper and promptly cracked the windshield :evil:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 181 times
Post by bmdubya1198 »
default wrote: Fri Nov 29, 2019 6:00 pm Heater core. And since I only watched the how to video once I didn’t remember where to clamp the lines off so I’m really glad I had a full jug of euro fluid after my impromptu coolant bath. Fun times.
Yeah... couple tips on the heater core... clamp off the two heater hoses in the engine bay (if you're not draining/flushing the coolant at the same time) with some hose clamp-off pliers, and place a large trash bag under the heater box before you remove the lines. Otherwise, you'll be cleaning up a lot of coolant from your carpets!
'00 V70R Venetian Red/Charcoal M56 Swapped 199k
'03 S60 2.4T Silver/Black 117k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
amblerman
Year and Model: 1999 s70
Been thanked: 40 times
Post by amblerman »
ZionXIX wrote: Sat Nov 30, 2019 7:07 am Change my wiper blades. The passenger wiper arm slipped out of my hand after removing the old wiper and promptly cracked the windshield :evil:
Unfortunately I've done that as well . On my 97 jetta I had a while back. In my case the wiper arm was only about 3 inches off the glass when it slipped but it was till enough of a jolt to make it a very expensive wiper blade replacement.
It really stinks.
I feel for you.
Has thanked: 376 times
Been thanked: 1171 times
Got Clarke the parts 1998 ready for the last two take downs, front and rear suspension, complete.
Moved parts to shelves in garage, moved Girl Beetle into garage before 15 inch snow storm
Put Snows on both Evita the S70 and Elizabeth the T5, that’s 40 lug nuts !
Link To Volvo Glossary
BlackBart
Has thanked: 76 times
Been thanked: 64 times
Post by BlackBart »
Oh...that sucks! I feel your pain!
1994 850T wagon
Is it time for a 1964 122 wagon?
for your amusement, from a brake caliper box found cleaining garage
You can’t make this stuff up...
bmdubya1198
Re: for your amusement, from a brake caliper box found cleaining garage
abscate wrote: Sun Dec 01, 2019 5:22 am You can’t make this stuff up...
Wow, those are really important warnings... I don't know what you would do without them! Brave soul taking on that job!
Started to swap the control arm bushings in the S60 yesterday... have to continue this morning since my dad thought he was a master at using my press and destroyed two Lemforder bushings... $115 later on Autozone bushings (ouch... Lemforders were $36 for the pair!) and we've got one in.
Funny, since I bought that press I have yet to use it. My dad and my cousin always manage to take over and do something stupid with it.
'99 BMW 528i
'01 Mountaineer 5.0
1998v70xcbill
Year and Model: 1998v70xc
Been thanked: 3 times
Post by 1998v70xcbill »
Semi broke down, going to job this morning. About 10 mile from home, car dies and won't idle, difficult to start. Able to get car into near by parking lot. Running very rough with foot on gas, in park. Drive will stall engine even with foot on gas. Open hood and disconnect MAF, Start car, runs better and head back home. At home remove distributor and find oil (I had noticed oil from the weep hole). Oil seal had competely fallen out. Clean it all up, used some retaining compound (loctite rc/609) and put the old seal back in. Cleaned up old spare dist cap ( to save time and avoid oil cean up) Just misfire codes, and maf code, reset all good. Glad it didn't break down driving kids during holidays (airport). Old seal went back in very loose. I at first used very little retaining compound, then added more after it went back in so easily.
This is the first time since I've owned, in six years , the car died when running. I once had a no start with a fuel pump problem.
Funny thing I knew I had an oil leak there. Tools needed 3mm hex, flat blade, 10 mm socket. Good things to carry, with spare rotor, fuel pump relay jumper. and torx
258k miles,
Bill
edit: second time car died when running, (ignition coil failed 1/4 mile from home).
Will check crankcase pressure. pcv should be good.
Last edited by 1998v70xcbill on Mon Dec 02, 2019 11:25 pm, edited 1 time in total.
Bill, check your crankcase pressure. If you out the seal back in and glue it, the next one to blow out will be the cranki seal, yikes
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 66 times
Been thanked: 57 times
Post by WhatAmIDoing »
Due to some oil getting spilled on my FCP return box, I now have a brand new Mann, not opened in dirty box, cartridge oil filter for a 99-00 P80 (and possibly other models). Mann Oil Filter HU819x free to good home, I have no use for it. E Showell, abscate and kahl have first dibs to balance the karma debts. Will hold for 96 hours, after that it goes to first user to PM me a mailing address. Happy Holidays!
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out :cry:
Knows enough to be dangerous :wink:
