What did you do to your Volvo today?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 9 times
Been thanked: 37 times
Post by FLXC90 »
Great fam, your dinosaur needs antlers!
Current Volvos:
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 73 times
Been thanked: 21 times
Post by smacknab »
Replaced my power steering pump with a junkyard unit. Funny enough the Haynes manual instructs you to remove the bolts that hold the two halves of the pump together, as apposed to the bolts that hold it to the bracket.
After I got a check engine and a P0118 code, so I'm worried I messed up the wires somehow.
99 s70 NA Manual - >223k miles
Mods: Accidental C70 Delta link, V70 Left Dog Leg
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 47 times
Been thanked: 193 times
Post by bmdubya1198 »
smacknab wrote: Fri Jan 10, 2020 6:15 pm Replaced my power steering pump with a junkyard unit. Funny enough the Haynes manual instructs you to remove the bolts that hold the two halves of the pump together, as apposed to the bolts that hold it to the bracket.
Check your coolant temp sensor wiring. It’s been known to fall apart, so it would be a good idea to check that out.
'00 V70R Venetian Red/Charcoal M56 Swapped 200k
'03 S60 2.4T Silver/Black 118k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'98 V70 GLT Black/Beige 205k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
smacknab
Post by smacknab »
The sensor itself is new and in good shape, but the other side of the wiring is not looking so good. I'm not sure where it goes but I'm gonna figure out how to refresh that.
Has thanked: 411 times
Been thanked: 1267 times
smacknab wrote: Fri Jan 10, 2020 8:33 pm The sensor itself is new and in good shape, but the other side of the wiring is not looking so good. I'm not sure where it goes but I'm gonna figure out how to refresh that.
Drops down into the wiring harness. Get your splice Gear! Good time to try those newsolder crimps !
In Boston WED Jan15
Link To Volvo Glossary
smacknab
Post by smacknab »
abscate wrote: Sat Jan 11, 2020 6:30 am
In Boston WED Jan15
Ah shoot I'm leaving for Greece on Wednesday! I reset the code and I'll see if it comes back, but otherwise I'll have to catch you next time!
smacknab
Post by smacknab »
Replaced the front left CV Axle and gave the car it's first official oil change (Mann filter and new plug and washer). The CV axle was the last fix that I knew about when I bought the car, and it's now been about 3000 miles of me having the car so I thought some might find this amusing- this is everything I've done or had to do to the car since buying it:
Oil and filter (blue AutoZone filter)
Coolant flush (volvo)
Timing belt (water pump and pulleys, FCP Euro kit)
Thermostat (FCP euro)
Coolant temp sensor (FCP Bosch)
Serp Belt
Spark plugs (double platnum Bosch)
O2 front sensor (Bosch)
Air Filter
Fuel filter
Cabin air filter
Starter (used)
New Battery
AC Delete (sourced and installed bracket)
Alternator (used unit)
Serp Tensioner (after market)
Engine mounts (bottom right OEM, aftermarket trans torque mount and ipd Poly top bushing)
Manual Transmission fluid (volvo)
Calipers (rebuilt), Rotors (new), Pads(new)
+flushed and bled brakes with new DOT4+
+inspected parking brake (needs a clip on left back wheel)
Craigslist Winter tires + rims (balanced)
Head gasket (Volvo)
Valve stem seals (Volvo)
Surface Head
PCV Kit (fcp)
Replace Dipstick tube and dipstick (updated model)
Front vaccum lines
Radiator hoses (Volvo + 1 aftermarket I forgot to buy)
Coil boot
Coolant Level sensor (FCP)
Cleaned throttle body (and new gasket)
Cleaned MAF
Negative Battery cable crimp
Vaccum hose behind the fuel filtel (fuel evap?)
Heater core (new Behr heater core)
Power steering pump (used unit)
Power steering flush (green fluid)
CV Axle Front Left (aftermarket from API)
First 3k mile oil change
You had better get married fast before she figures out that’s just a good start
smacknab
Post by smacknab »
I try not to tell her when I'm fixing stuff anymore haha
99commutervolvos70
Year and Model: 1999 S70 GLT
Post by 99commutervolvos70 »
Installed a Boost gauge on my 99 GLT. The main reason why I installed it was to diagnose an issue that I was having. I learned a few things... I am over boosting on initial acceleration, then boost cut kicks in at around 10 or 11 psi (depending on how accurate the gauge is). If I feather the throttle and keep it below 7 psi, The performance is perfect. Now I just need to chase what is causing the boost spikes. Boost Sensor is brand new as well as the TCV solenoid. I tested the wastegate actuator with a mightyvac and it moves. I need to take the shield off tomorrow and see if the the wastegate itself is binding.
well here is a pic and some videos :D
https://www.youtube.com/watch?v=jtYmFSQTyAQ
https://www.youtube.com/watch?v=k7gVsC0WNLE
