What did you do to your Volvo today?
- Has thanked: 52 times
- Been thanked: 201 times
You checked the wastegate with the pressure setting, correct? Most Mityvac models only do vacuum.
I believe the GLT should be set to 2 PSI, but I'd have to confirm that.
00 V70R Venetian Red/Charcoal M56 Swapped 200k
03 S60 2.4T Silver/Black 118k
07 XC90 V8 AWD Sport Titanium Grey/Black 174k
92 245 Base White/Beige 249k
98 V70 GLT Black/Beige 205k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
00 S70 GLT Mystic Silver/Taupe 253k
91 944 Turbo Dark Green/Beige 175k
93 944 Base Beige/Beige 221k
98 S90- Silver/Gray 207k
95 850 GLT Tropic Green... crushed
01 S60 2.4T Black/Black 230k
88 744 Turbo M46 Beige Metallic/Beige 188k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
- 99commutervolvos70
- Year and Model: 1999 S70 GLT
Yes, the mightyvac I used only has a vacuum gauge on it. I basically wanted to check if the diaphragm was leaking, which it is not. When i applied pressure to the wastegate actuator it moved and held.bmdubya1198 wrote: ↑Sun Jan 12, 2020 8:04 am You checked the wastegate with the pressure setting, correct? Most Mityvac models only do vacuum.
This issue just happend recently, so I am thinking it may not be a setting issue. I haven't touched anything turbo related in the 60k that I have had it. The car has over 277k on it. The wastegate actuator DOES look to be very shiny and "new" looking (doesn't look like it has 277k on it), would love to get one of those deals from Ipd and check the base setting.
For now, I think I will just hook the wastegate actuator directly to the port on the turbo and see if it reaches the 2psi setting. I installed a new pierburg TCV and a Bosch Boost sensor.
I drive this car every day a minimum of 80 miles a day, so I will eventually get to the bottom of it
Probably something simple, but a pain to pinpoint. That's usually the case with boost issues!
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
Well I unplugged my TCV electrically, which should directly link the red and yellow vacuum hoses. Now I get progressive boost to about 3psi with no spikes at all. So either my new TVS is defective or my original one was defective and I didn't notice it because my wastegate actuator is not adjusted properly...bmdubya1198 wrote: ↑Sun Jan 12, 2020 11:38 am Probably something simple, but a pain to pinpoint. That's usually the case with boost issues!
So I will have to do some searching to see what the spec is for the LPT turbo. Perhaps someone previously replaced the wastegate actuator that was meant for a T5 that is set at 4 psi?
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1339 times
Is that right? Is default no power setting on a TCV connecting full boost to wastegate?
I though it dumped to blue/ Snorkel
Link To Volvo Glossary
I believe when it is disconnected electrically, it defaults to full pressure to the wastgate (same as connecting the wastegate actuator directly to the turbo), which will keep it closed until it reaches whatever the wastegate rod was initially set at.
It is slower to build boost with it bypassed, but it does not overboost.
It did set a CEL on my 2nd trip P0234. Tomorrow I plan on checking the wastegate setting with a pressure gauge teed into my mightyvac. I have a feeling it will be around 3 to 4 psi. I guess it is supposed to be around 1.8 psi for my LPT.
It dumps when it is energized which keeps the wastegate shut, which increases boost.
I've been studying this system for a few days now
Moderators can move this if it is posted in the wrong area.
The TCV stays open when it is not connected to the ECU. The TCV is closed by the ECU grounding the constant voltage (I believe), allowing boost to build. 100% duty cycle is full boost, 0% is wastegate pressure.
LPT WG setting may be 1.8 PSI now that you mention it. I had a chart somewhere...
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
- Has thanked: 129 times
- Been thanked: 363 times
I rarely post any pics of my cars - here's one!
The V70 is 427 black, here it is the day after finishing a 2,000 mile round trip over the December holiday. I like the 427 color, it edges a bit toward gray. The 850 R in the background is standard 426 Black, you can see the color difference somewhat here.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
Are those the Perfo or Columba wheels on the V70? Paint looks incredible on a decades oldcar(s)
- raivis_rsn
- Year and Model: V70 1999 TDI
- Been thanked: 6 times
