IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
What did you do to your Volvo today?
cmblackburn
Year and Model: 1998 S70 T5
Re: What did you do to your Volvo today? (now Sticky!!)
Post by cmblackburn »
Unfortunately, blew it up, again! I had the car perfectly ready for Carlisle this year and my torque converter seal blew (5k after replacing the engine)... Took it to Swedish Imports and they diagnosed it as a bad axle seal. $260 later it was still peeing fluid on the ground and the flashing arrow of doom lit up alongside the check engine light. I moved it 20 feet and it peed out a quart of fluid on Saturday. Devastated, we cleaned up the S40 and took it to Carlisle- where I picked up a 120k mile M56H swap kit. Though I have a spare automatic in the garage, I figure do it once and do it right- manual transmisison. Still trying and failing to source a flywheel, I've already purchased a clutch kit and hundreds of dollars worth of other stuff. I question why I keep this thing alive still...Justin gave up on it years ago :roll:
1998 S70 T5"M", 273k "The Blue Turd"
2004 S40 2.4i, 164k "Cosmo"
2011 VW Jetta SportWagen TDI 6MT, 65k "Zoe"
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 66 times
Been thanked: 57 times
Post by WhatAmIDoing »
I really wish I would have known about Volvos at Carlisle. I was in the area that weekend with my T5M and only about an hour drive away. Kind of sad I was so close and missed it (though I'm sure my wallet is glad I wasn't there).
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out :cry:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 181 times
Post by bmdubya1198 »
Changed the oil on the XC90 yesterday. Turns out it was a little over a quart low... which would explain the low oil level message. It's weird, the dipstick appeared full, but I'm glad to know it doesn't need a $225 oil level sender! No low oil notification so far, so I'd consider it fixed.
Pulled the dash pad from the R and pulled the cluster. Also ran the boost gauge vacuum hose and wiring for the boost gauge back light through the driver side air vent so I can mount my gauge in the vent for easier visibility. I'll post pics once it's all together!
cmblackburn wrote: Mon May 27, 2019 11:29 pm Unfortunately, blew it up, again! I had the car perfectly ready for Carlisle this year and my torque converter seal blew (5k after replacing the engine)... Took it to Swedish Imports and they diagnosed it as a bad axle seal. $260 later it was still peeing fluid on the ground and the flashing arrow of doom lit up alongside the check engine light. I moved it 20 feet and it peed out a quart of fluid on Saturday. Devastated, we cleaned up the S40 and took it to Carlisle- where I picked up a 120k mile M56H swap kit. Though I have a spare automatic in the garage, I figure do it once and do it right- manual transmisison. Still trying and failing to source a flywheel, I've already purchased a clutch kit and hundreds of dollars worth of other stuff. I question why I keep this thing alive still...Justin gave up on it years ago :roll:
M56 is definitely the right way to go! I saw your post on FB about the flywheel... I'll keep my eye out for you.
I feel the same way about my R... I'm hoping a new cluster will fix all of the CAN bus issues that seem to be constantly appearing. I'm almost ready to just pull the turbo to investigate my low boost condition further.
Maybe I'll swap out that VVT hub today to finally stop that awful grinding every time I start the car!
'00 V70R Venetian Red/Charcoal M56 Swapped 199k
'03 S60 2.4T Silver/Black 117k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
VTs70T5M
Year and Model: 1998 s70 t5m
Has thanked: 2 times
Post by VTs70T5M »
Poly engine mount, gear oil change, rear cam seals, ipd tcv, silicone vacuum lines, silicone turbo pressure hoses, 1.5 turn wga adjust, e3 diamondfire plugs, new bougicord wires, slotted rotors n ceramic pads, cleaned painted engine cover.. Oh 2 pod pillar w/ 52mm boost gauge as well. Plotting a wideband for when install mbc.. Also cleaned ptc nipple.. I get 28hg at idle Think just cheap gauge issue?
VTs70T5M
Post by VTs70T5M »
bmdubya1198 wrote: Tue May 14, 2019 7:31 pm Wow... 0.041" is a lot! Definitely time for new plugs!
I thought mine were bad. They said Volvo on them so questioned were originals at 198k .036
WhatAmIDoing
Drove the T5 today into the mountains for a hike. Got back to the car just as thunderstorms were approaching. Turned the key on, fuel pump buzzed, turned to start and.... nothing but a click from the relay. Fortunately I was parked facing downhill, so I just bumped started it (pros of having a manual). When I got home, starter started functioning normally again. Will have to check the wiring tomorrow.
Also met an interesting fellow who specializes in antique car restoration. He has a 1978 Volvo 240 turbo. He told me if I can get it driveable, then I can have it. Apparently it runs but doesn't have enough power to move itself (sounds like a 240).
Also may have found a potential parts car in Canada for my AWD, a 99 S70 AWD with one big goodie attached.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 376 times
Been thanked: 1172 times
Easy things first.
Battery and cables
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
bmdubya1198
WhatAmIDoing wrote: Tue May 28, 2019 10:02 pm Drove the T5 today into the mountains for a hike. Got back to the car just as thunderstorms were approaching. Turned the key on, fuel pump buzzed, turned to start and.... nothing but a click from the relay. Fortunately I was parked facing downhill, so I just bumped started it (pros of having a manual). When I got home, starter started functioning normally again. Will have to check the wiring tomorrow.
You should grab that 240 and send it down to me to take care of it :mrgreen:
I've actually got my eye on a cheap '99 S70 AWD right now. I'm hoping it sticks around a little longer so I can go grab it!
'99 BMW 528i
'01 Mountaineer 5.0
:lol: :lol: :lol:
Last night - drove my T5 through the thunderstorms and Tornado warnings in North NJ...yikes
bmdubya1198
abscate wrote: Wed May 29, 2019 8:30 am
:lol: :lol: :lol:
Yeah... I also bought a "cheap" V70R a little over a year ago :lol: :lol: :lol:
I'll take this hot dry weather over tornadoes, that's for sure! It's awful, but it could always be worse!
'99 BMW 528i
'01 Mountaineer 5.0
