V70 2.5 1998 Starts but doesn't run
belg
Year and Model: 1998 v70
Post by belg »
Our volvo does want to run unfortunately. It does start, motor turns, seems to run, and after 2 sec it dies. When you try to give some gas it dies immediately. We do get spark, and there is enough pressure on the fuel rail. We did replace the immobiliser ring, and tried to start with the spare key.
What could it be?
Here is a link to a video where we try to start the vehicle:
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Bad transponder(chip) in the key?
Immobiliser kicked in....that's for sure.
Does that car have Lpg system installed?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
belg
Post by belg »
We tried the spare key, so it would be strange if both transponder key's are bad.
Yes the car has a LPG system installed.
misha
Post by misha »
Are you sure that second key is chipped?It could be just a regular spare key for opening door locks.
You're right....there is almost no possibility that both keys are bad.
Then....immobiliser ecu maybe.When car starts and run for 2 seconds then dies it's classic symptom of immobiliser kicking in.
When that happens...is red light in the center of dashboard by the windshield on or blinking?
What alarm system car have....original Volvo guard or aftermarket.
Is that Venturi LPG system.....sequential systems don't need that discharge plate(detonation discharge plate) on air filter housing?!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
belg
Post by belg »
Reinstalling the immobiliser ring seemed to have solved the issue. After a few tries and short runs we have an other problem. Now the motor doesnt start anymore, not even close. Normally when you turn the key in the second position you'll hear the fuel pump giving one pulse to start. Now the pump pulses first 7 times in a row, and then with a pause of a few second between each pulse. When I try to start the car, I here the starter motor turn, but there is no spark.
Does anyone have an idea?
misha
Post by misha »
Check MAIN fuel injection relay(the grey one) on cooling fan carrier and fuel pump relay.
You didn't answered about LPG system....is it venturi or sequential?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
belg
Post by belg »
It is a Sequential system.
misha
Post by misha »
Hmmm...WHY you have a detonation flap installed on your airbox?It's not needed on sequential system.
It is needed ONLY on Venturi and Lambda control LPG systems as a precaution measure.
Check those relays i mentioned in mine previous post.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
belg
Post by belg »
I don't know why the detonation flap is installed, it was already there when I bought the car. I checked and jumped the fuel pump relay "103", no problem with that. I'll check the one above the fan.
