merhaba
aranıza yeni katıldım
klima kontrol ünitesi başlatma butonu yeşil ışık yanıp sönüyor.(
continuous)
hava kanalları sürekli aynı pozisyonda kalıyor.
sizce problem neden olabilir?
2000 model s70 t5 climate control panel problem Topic is solved
- Been thanked: 4063 times
I know just enough Turkish to read that you have a climate control problem with the light?
If the lights flash, the climate control reads an error and the code should be read to find the error.
- Has thanked: 2196 times
- Been thanked: 1850 times
Saw the other post 'can' has added to on the subject.
Sorry I don't know a word in Turkish, but welcome to MVS.
When the green A/C lights flash there are several obvious possibilities:
1) A/C pressure is too low for compressor to run - can be as simple as adding more Freon, to an A/C compressor clutch adjustment needed, to a leak in the system.
2) Is the cabin cooling fan working?
3) Do you have ECC or MCC? MCC uses cables from the unit to adjust the cooling flaps, the ECC uses small servo motors.
These are usually the first places to check, then from the results we can help you further. If you can get access to a code reader that reads Volvo codes that makes fixing a whole lot easier.
- can
- Year and Model: 2000 s70 2.0 t5
- Has thanked: 23 times
thanks for the answer scot850, abscate
They said that the fault at the volvo service was from the clima control panel.
The new panel is the same fault we have installed.
Volvo (vida) tied to fault detection
Tried to reset the conditioning system but the system failed
All of the climate system should be dismantled
I had no time 2 days 4 days 1 week To identify the malfunction
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Need more information.
Here's a write-up on diagnosing my own ECC fault:
https://www.matthewsvolvosite.com/forums ... te#p393260
https://www.matthewsvolvosite.com/forums ... it=climate
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 316 times
- Been thanked: 531 times
Are you getting any flashing lights? If so, which ones?
- can
climate control unit ON button blinkig green led light.
Calibration with fault finding device would be unsuccessful
Unresolved problem
I can sell it because it is my car because there is a problem spare parts
Unresolved problem
Trebliker!!
- 1450 Views
Last post by JRL
- 2183 Views
Last post by volvolugnut
- 1237 Views
Last post by Tomaszabc
- 11 Replies
- 6743 Views
Last post by maxi948
- 3886 Views
