Yaw sensor location?
gbmarc
Year and Model: 2005 S60
Post by gbmarc »
I have code BCM-0114 "Communication with Yaw sensor, signal missing". Before I get the BCM checked out, I would like to eliminate the YAW sensor end. I have seen instructions for the XC70 but not for the S60.
I removed the front 2 bolts of the passenger seat (RHS) and lifted the carpet with a bit of struggle, but didn't see any sensor.
Can anyone post a photo or give directions?
Thanks
Mark
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Here you are:
http://volvopartslisle.com/assembly/63580773/Overview
(Position # 1 on diagram)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
gbmarc
Post by gbmarc »
Thanks for the link but it's not much help. I have the seat out. There's nothing attached to and under the seat except the wires and connectors for the seat controls. Under the carpet there are two black plastic vents but no Yaw sensor. I've looked pretty carefully and there's nothing there. Someone else mentioned under the center console but it's not clear how to remove that without breaking something.
